Old Fri, February 20th, 2009, 10:14 AM
grizz, I don't see ANYTHING in your custom options that would cause a rough idle or funny gas smell. It sure sounds to me like for some reason you are running (idling) way rich, and I can't think of any setting you have access to that would cause that to happen.
When you return to stock, does it idle properly and does the exhaust smell normal?
I'm having trouble understanding what you mean when you say: "If I don't use the Load Previous Settings button and just load the level 2 tune and change the tires and gears it does but I can't tell if the changes took." What are you looking for to "see if the changes took"? (I don't see anything - except that the speed and odometer readings are correct).
I'm with you on being puzzled about some of the settings being reloaded even though you don't ask for them though. If I get what you are saying right, you are seeing the shift firmness still at +1, +1, 0 and the Max speed at 125, even though you don't "reload previous settings"?
I suppose one approach would be to use the Custom Options menu to reset everything to the settings Bill gave you when he wrote your tune, or was this the "canned tow tune"?
