Old Mon, December 13th, 2010, 06:34 AM
Whatever you do, you'll have to match your inferred table to the output voltage of your sensor. If the sensor only reads 3.8v at WOT, then the table should reflect that. If it's reading 4.4v at WOT, it should again reflect that. This way you can make the most use out of your pedal travel.
