Old Mon, December 13th, 2010, 10:43 AM
It might have been bad gas, might be overly lean, there are a bunch of possibilities. I wouldn't be romping on it too much because you are for sure running leaner than you were before adding the intake, no way to avoid that on a stock vehicle. You are going to need that MAF sensor recalibrated to compensate for the larger diameter tube around it.
