Thread: No WTS light
Old Mon, December 13th, 2010, 03:00 PM
cj45lc cj45lc is offline
Something there makes no sense. If the Glow Plugs are activating (via observation of the battery gauge or by dimmer lights) and the WTS light is not illuminating, I'd almost say there's an issue with the bulb itself. Since the truck itself seems to be functioning properly, I'd not worry too much about it. I would, however, verify the cause of the issue with the WTS light before disregarding it.
How long did it take before the WTS finally did start working? Any idea? Is it repeatable? Let us know so we can try and reach a conclusion.
This is the first time it's happened. That was my first thought the WTS bulb & I turned key on & off 3 times without the WTS lite but the glow plugs kicking on each time but after letting truck run for 15-20 mins I started it again & WTS lite worked like it should & has worked since. I'll crank truck again this eve to see what if anything happens but like I said it just happened Sat. morn but after that first start Sat was fine rest of the weekend & I probably started truck 10-12 times through the weekend. Just a real head scratcher to me. BTW all gauges-lights everything works normal.
