Thread: spikes in maps
Old Tue, December 14th, 2010, 02:55 PM
GTS GTS is offline
e-mail is gtsmotorsport@yahoo.com.
Thanks for the input. Do you have any explanation as to why the APP map is that way or is it just that it is what it is?
If I smooth out that dip is it going to affect the other maps so I'll need to go make adjustments elsewhere as well.
This brings up another question, If I make a change on one map that changes things on another map will those changes on the other map show up on the actual map. So if I move something on one map and have the other map that is affected as well pulled up side by side will I see the changes being made by the map I'm working on move things in the other affected map? Or are all the changes to the other map more or less behind the scenes
Dave can you please explain a bit what you mean by not much resolution? You mean the increments aren't as fine as in the SD files you have?
