Old Sat, January 1st, 2011, 01:57 PM
GTS GTS is offline
Default Couple questions.
OK so I have a couple more questions. First if I want to adjust a large area of a map to a certain value is there a way to do this all at once? I know you can highlight the area and raise it with the + or - puttons but when you do that it raises all the highligted areas the same. So if there is a taper to the map it won't flatten it out. If you double click on one spot or hit enter it will bring up a box that you can put a value in. That is what I'm looking to do for a large area but when I highlight a large area and hit enter I don't get the box to enter a value into.
Also I have a sniper chip. I'd kind of like to see what the tuning looks like on it. Is there a way to pull the tunes off it and load it up in my Minotaur software and see what they look like?
