Old Mon, January 3rd, 2011, 04:07 PM
God & Guns
If it is just for your personal use then you can adapt a little formula for finding the correct tire size on the programmers. You take the GPS mileage and divide that by the odometer mileage (resulting in a number around 1.08). Multiply that number back to your odometer to find the true number of miles you've driven in that time frame...or does this also sound funky?
Well the spedometer is right up untill 35-40mph....then it starts to get off. So sometimes its right...sometimes its wrong. Will A MODIS not correct for the different tire size?
