Thread: weired idle
Old Fri, January 14th, 2011, 11:18 AM
God & Guns
Originally Posted by epowers777 View Post
Well the sensor did not fix the problem poop! I am about ready to pull the injestors and make sure there are no problems underneath and check the torque . Im running out of stuff to do.
That sucks....would be interesting to see if the blue cps would do anything. But your problem could lie with the ICP sensor or IPR valve. Right now I'm building up my bank, and when I get a set amount saved up, I'm just going to start throwing parts at it. And if they don't fix anything, then I have a spare
