Old Sun, January 16th, 2011, 01:09 PM
Originally Posted by lbjailer View Post
Thanks, I will try again. I need to get my HEX code into the Gryphon, so I will try to see if it will load (save) my stock tune, and not make any changes to the ECU, then plug it in to Pegasus.
I don't think you will get the hex code into the Gryphon until you do your first programming session.
If I'm right, what you might try is:
Restore the canned tunes and then program your truck to the Level 1 transmission tune (no customizations). This will also store your stock tune into the Gryphon.
Return your truck to stock and THEN connect the Gryphon back to Pegasus to proceed.
