Old Sat, January 22nd, 2011, 01:30 PM
skizriz skizriz is offline
skizriz is on a distinguished road
. I've already sent in to Autoanything.com where I bought it, about a return/exchange. I talked to Edge again last night, and still got the same thing. "They are still looking into it".
Still no answers.
Where I really scratch my head it that even on level one, which is supposed trans only, if I bump up the shift firmness and shift points it has the same outcome. Runs rich.
What would the shift points have to do with the "TPS inconsistant with MAF" code that I got?
I'll give the WOT fuel a try and see what happens. Still don't want to go through the trouble of an exchange.
Reprogramming right now.
Level 1
tire size 2565
gear ratio 3.55
rev limit 5,200
wot shift points 4,800 4,800 4,600
shift firmness +10 +10 +8
standard shift + to max
I turned the WOT fuel down as far as it would go It was reading +1.6, went down to +.9
Update. No change. Lumpy idle around 900 rpm, sounds like it has a huge cam. Black smoke, hesitation. Engine load % display is stuck at 70%,even at idle.
