Old Sat, January 22nd, 2011, 09:07 PM
FARMBOY22 FARMBOY22 is offline
FARMBOY22 is on a distinguished road
I have a hard time following this.......without volume there cannot be any pressure, pressure is basically a measurement of restriction (to the flow/ volume).
I am sure you can have 450HP with some A's, but it wont be as easy as you could with a set of Hybrids.
I think we have gotten away from the subject a little. The only point I was trying to make was that if 3000PSI is demanded from your HPOP the HPOP doesn't know or care which injector is in front of it. The HPOP will pump as much volume as it takes to try and maintain that 3000PSI which will be the same as the intensifier pistons are the same. It's the additional oil flow or volume the A code will need to maintain that 3000PSI for a longer time because its barrel is smaller and the plunger must travel farther to inject the same amount of fuel and also taking more time that will hinder it. There by flow not so much as pressure is the problem on high HP engines ,but shouldn't be as much a problem on lower HP engines. Of course if the HPOP can't keep up the pressure will also be low. I was wondering at what point or HP range is the Hybrid truely at an advantage. I know at stock levels the A is best and at 600HP+ Hybrid is better, but where is the split between the two as to which one is better?
WHEN IN DOUBT FLOOR IT!
IF IT'S TOO LOUD YOUR TOO OLD!
99.5' F-250 EXTCAB 4X4 6SPD 4" LIFT 35" TIRES 3.73 GEARS
K&N INTAKE, GTP38R W/TURBO MASTER WASTEGATE CONTROLLER,
203DEG THERMOSTAT, EVO II,AND MBRP COOL DUALS EXHAUST NO MUFFLER
