Thread: weired idle
Old Sun, January 23rd, 2011, 10:25 PM
Ok I got a update. I took if the driver side valve cover and did some inspection. All the injectors were flat (used a level). I re torqued the valve bridges 20 ft pounds. About three were loose (barely) and re torqued my injectors 10 ft pounds which is 120 inch pounds. ALL my injectors were loose! Some quarter turn some 2 turns.
While I was there I did the quarter mod. The plug was unplugged a hair so I put the valve cover on threw 4 bolts in starter her up warmed her up and it still has the funky idle but it idled much quieter. So I'm going to do the passenger side next and will write back.
