Old Wed, January 26th, 2011, 09:32 PM
Sorry, because your truck is in a problematic year range you cannot upgrade your programmer without literally upgrading to a CS or CTS. After you updated did you go and re-enter your proper tire size and gear ratio? If any of those are off it will throw off your odometer and then the math will show poor mileage.
Ah, Longshot - doesn't he have a 2005? If so, there should be no problem upgrading to a Gryphon.
And, Kurt, you say your mileage dropped after you updated the firmware on the Edge? I suppose they might have changed the calibrations, but that would be the only thing that could have effected mileage. Did you call Edge about this?
