Originally Posted by Flats1
I know the cats are clogged because I have been having trouble with my truck and finally had the time to check the cats and the one side it completly gone I actually poured out some of the cat onto the ground. No we dont have any emmision testing here. So what aftermarket cats will work for my truck? And were would the o2 sensor go?
Go to summitracing.com. Enter your info and you should be able to find which one. But I have talked to them and most of thier high flow cats will work as long as they match up on the pipe you have going in and coming out. I can't remember off the top of my head where you get the dummy sensors. Google "dummy O2 sensors" is how I found them. If you do replace your cats, there are 4 sensors. In the front of both cats and one being both cats. Your factory pipe should have places already there for easy install. Just make sure you have them put in after welding is done as not to burn them up! I hope this helps. Good luck my friend.
2nd place is 1st's loser!
