Thread: HPO health
Old Fri, January 28th, 2011, 08:19 PM
eabrust's Avatar
eabrust eabrust is offline
electro-mechanical geek
Alright, finally got my new toy(s) in and tested actual ICP voltage today.
First I got a programmable digial multimeter tapped off the ICP sensor output lead (and scaled such that 0 volts = -143 psi, 5 volts = +4015 psi, (based on line fitting the ICP volts vs pressure data I could find)).
With KOEO, reading was 74 psi (or .26 volts)
When idling, readout is ~550-600 psi fluctuating (or ~.87 volts)
When in the 80DD tune, the readout plateaued and stuck at 2180 psi (or 2.79 volts) no matter how long or how hard hammering the accelerator. This is similar to what I saw w/ AutoEnginuity, except that value AE reported peaked at 1740.
When in the 100Perf tune, the readout, the peak value I saw was over 3800 (or 4.75 volts)
So there is a slight difference in overall values between voltage output and AE reading, likely an error in how AE scales or how I have my scaling on the readout. But in general, this shows that my 80DD tune still has something funny about it, which caps the ICP pressure at what ever can be achieved with an IPR DC of ~60% (which is what it always maxes at in the 80DD).
So I'm happy to report that AE seems to be pretty truthful in reporting everything I've documented, which was my big worry.
Bill, for a cross check of my sanity , could you please look at my 80HP tune and validate if you see something funky please?! Pretty Please
As far as the multimeter gauge I found, if anyone cares, I got these Auber multimeters (Automobile Multimeter for EGT, Boost, Red [SYL-1813R] - $48.50 : auberins.com, Temperature control solutions for home and industry), for the price, they are awesome! They will do 0-5V, 0-10V, RTD, thermocouples, mV signals, etc. I bought 2 and am hooking up the 2nd for fuel pressure gauge. They have peak/min value recall, and alarms, and I like the fact if you know what your sensor puts out, you can calibrate the readout to know what you got for any kind of sensor. I attached some pics of it very temporarily hooked up for reference, the pictures don't do it any justice.... but I like it alot. Plan to put em on the dash next to the Gryphon.
Eric
2006 F350 King Ranch
Gryphon & PHP tuned FICM
EGR deleted
4" Turboback
