Old Mon, February 7th, 2011, 06:07 PM
Originally Posted by hampsterzone View Post
Excellently put! I appreciate your response. Any thoughts on exhaust causing the O2 sensors to relay lean conditions?
The lean codes from the o2 sensers can be atributed to a vacuum leak occuring after the maf up to the point of combustion......after combustion the exhaust may cause these but before the o2 senser if there are......broken welds, broken header studs, cracked manifolds, bad gaskets.......
