Old Wed, February 25th, 2009, 04:27 PM
grizzstang grizzstang is offline
grizzstang is on a distinguished road
Gryphons and Edges don't program well when the battery voltage is low. If you have any doubt, connect a low amp (2-10 amp) charger and leave it on while you are programming.
I don't understand what it "doesn't like" about adjusting WOT shift points.
I am going to put the charger on it tonight on 2 amp and let it charge up fully, then I will load the program, with the charger on, and make all the changes I want to make and see if that works.
It goes back to what was happening before. If I adjust anything else other than tires, gears and shift firmness my truck freaks out. If it even starts it will idle like a race car and push enough fuel to make your eyes burn.
I know Bill is busy but I would kill to get an answer on the bolded question above does anyone else know?
