Old Wed, March 16th, 2011, 08:22 PM
ssredrino ssredrino is offline
ssredrino is on a distinguished road
Default check
check your oil to coolant temp
mine did this same thing when it gets warm the oil gets to hot and the injectors start mis-firing, my truck was not overheating but the oil temp was running 30-40 degrees hotter than the coolant
change the oil cooler flush the coolant system
check for a bad injector harness also
