Old Sat, March 19th, 2011, 05:49 PM
Originally Posted by Alcohol5LT View Post
yeah, i've saw the mixed results on another forum, but figured at least if there was a problem I knew I could get them out, a plus. like i said so far, no problems, i actually got the idle problem fixed today; seems after i cleaned the MAF meter again and then reflashed the programming on my truck the idle issue is completely gone, smooth as silk.
If I start having issues with them and have to pull any, i know i'll post it on the F150online forum, and if you'd like i'll do it on here too.
Yes, I would like to see pictures here as well as on f150online if you find you have to pull them. And, if you continue to have good results with them, we want to know that too! I've got nothing against Champions personally, and would like to see a solution to the 2-piece design adopted by Motorcraft.
