Old Wed, February 25th, 2009, 07:13 PM
twintips_17's Avatar
twintips_17 twintips_17 is offline
Let the Mud come!!!
twintips_17 is on a distinguished road
So, you're running 91 octane gas in an 87 octane tune? Using the manual guidance, you should advance the timing +2 degrees, not 2.5. (The manual, by the way is a little weak on math right here).
If you get a custom towing tune, make sure Bill knows you're using 91 octane gas. He'll build in the timing advance for you and tweak some other things too.
I did get a custom tow tune at 91. In the past i have been able to puch teh timeing to 2.5 without problems. Either way the point is that the new grypon will only advance it 2.0 in .25 incerments.
So does it advance the same as the manual states? And i only advanced it .5 up and so that would say i was running 88 octane acording to the manual. 91 should more then run on that with no problems?
Im so confused. I had my favorite presets in my ver 4.xx.xx and now they dont go the same into this one. Any custom tune ends up jinxing me even if i jsut mess with tire size
That should have no effect on how the engine runs.... Just shift points right?
SUPERcrew
AF1, EDGE, and EFANS with Magnaflow Exhast SISO.
Expy Console and Rear Seat Swap! Eagle 16's with 285-75/16 ST's
Gryphon Tuner soon to have custom tunes by PHP!
