Old Wed, February 25th, 2009, 07:37 PM
As far as I know, it should still have a +/- 5º timing adjustment. So does the problem only occur if you change the timing?
If you get a second, try loading the offending custom options and then remove the unit and plug the unit into your USB port. Use Pegasus to read the critical files (under the Utilities Menu). Send me the "Stock" and "Custom" files and I can see if something is getting chewed up in the custom process.
