Old Wed, February 25th, 2009, 08:19 PM
twintips_17's Avatar
twintips_17 twintips_17 is offline
Let the Mud come!!!
twintips_17 is on a distinguished road
QUOTE=Power Hungry;4570]As far as I know, it should still have a +/- 5º timing adjustment. So does the problem only occur if you change the timing?
If you get a second, try loading the offending custom options and then remove the unit and plug the unit into your USB port. Use Pegasus to read the critical files (under the Utilities Menu). Send me the "Stock" and "Custom" files and I can see if something is getting chewed up in the custom process.
Take care.[/QUOTE]
It happens to any tune i try and customize. I will try it in about an hour and i will do that if i can get it to sync with pegasus... Still havn't figured that one out.
But the timing adjusts in .25 incerments. I will go try it again.
SUPERcrew
AF1, EDGE, and EFANS with Magnaflow Exhast SISO.
Expy Console and Rear Seat Swap! Eagle 16's with 285-75/16 ST's
Gryphon Tuner soon to have custom tunes by PHP!
