Yep! That is one of the most common things as to why a Gryphon won't even power on. I blew that fuse the other day, and had the same problem, but I knew it right away as I always have something plugged into that outlet. I've started using a 25a fuse in that outlet as I have blown it several times will very little load on it using the standard 20a. But upgrade the fuse at your own risk.
