Thread: No Screen
Old Mon, March 28th, 2011, 01:54 AM
ticopowell's Avatar
Grown-up in training!
Originally Posted by roary View Post
Yep! That is one of the most common things as to why a Gryphon won't even power on. I blew that fuse the other day, and had the same problem, but I knew it right away as I always have something plugged into that outlet. I've started using a 25a fuse in that outlet as I have blown it several times will very little load on it using the standard 20a. But upgrade the fuse at your own risk.
If you are really worried about upgrading the fuse you should upgrade the wires between the fuse and wherever it leads to... that way you can have the bigger current draw without worrying about the wire burning up. , just my 2 cents
