Old Mon, March 28th, 2011, 11:01 AM
Originally Posted by pearsonrb View Post
I have a Gryphon CS in a 2010 F150, 4.6 3V 6 speed auto Supercab w 3.73 limted slip rear end. I'm running on Level 2 - Tow.
1. I replaced the stock 275 65 18 tires with 275 70 18's and keyed in the new size on the programmer. When my truck speedometer reads 68 mph, the Gryphon displays 65. All the tire calculators I've use on the internet say that it should be the other way around, that when the CS says 65 I should see 62-63 on the speedo. Which is right?
2. I was looking at my invoice, and it describes my programmer as having Economy, Tow and C 87 P tunes. But the unit actually shows Trans Only, Towing and Extreme as the tunes. Why is there a difference? (No Economy tune)
Thanks in advance for any help.
What you are currently seeing on the truck's dashboard speedo and the CS is the correct display. The dash speedo reads about 3% higher than it should, due to mechanical errors. BUT, your speed indications may still not be correct. You need to get your CS speed to agree with a GPS, or, get your truck's odometer to match your actual distance driven.
Your display of tunes is probably due to the newer truck and the way the CS is programmed for it. At this time, Edge will not allow Bill to make any adjustments in the transmission for 09+ trucks. The owner's manual was probably updated for that fact, but Edge has not changed the coding in the CS menu accordingly. So, I am certain the Level 1 tune is an "economy" engine tune. Level 2 is tow and Level 3 is performance.
(Looks like shotgun and I were typing at the same time.)
