At least on the 2wd, the fronts are "struts", the rears are "shocks", hence the difference in price. As already stated, the fronts require a little more labor and a specialty tool, so another difference in price. If you can get ahold of a spring compressor (HEAVY DUTY due to the size of the springs), then it is a very simple job and will save you some money.
Not sure if the 4wd has the same set-up, but I do know some of the parts are the same.
