Thread: No Screen
Old Mon, April 4th, 2011, 12:30 AM
Originally Posted by roary View Post
Yep! That is one of the most common things as to why a Gryphon won't even power on. I blew that fuse the other day, and had the same problem, but I knew it right away as I always have something plugged into that outlet. I've started using a 25a fuse in that outlet as I have blown it several times will very little load on it using the standard 20a. But upgrade the fuse at your own risk.
I would keep the original fuse size in there. Not just to save the wiring in the dash but also for the programmer. It is some rather sensitive equipment. If you are constantly blowing fuses then there is something you need to look at. If you are drawing too much from the socket then wire up another one. I have a total of four in my console. Three are on top that are made to run simple, low draw things like my GPS, chargers, etc. I've got another one underneath that is wired for about 25 amps but for now it just runs my CB radio. I use the actual cigarette lighter for keeping my MP3 player charged. I prefer to use my own wiring because just my console is able to handle over 60 amps. I decided to make it able to handle 6 100 watt lights and some smaller accessories...if I needed it to.
