Old Thu, February 26th, 2009, 12:30 PM
Load previous settings will load the LAST custom options entered. There is no buffer or history.
Wait, stop! We may be saying the same thing under different assumptions. I enter Custom Options and "Load Previous Settings" as my first option. Now I make a few changes, and select "Done" to start the programming. Doesn't this create a new "Previous Settings" file that is the sum of both the previous options and new ones I've entered? So, couldn't this be thought of as cumulative?
But, if you chose a tune, then open the Custom Options menu and select "Done" as your first action - I believe you are saying this will effectively "wipe out" all previous custom settings you may have had (and additionally may load bogus values for GR and TS).
AND, I want to verify one more thing. Custom options are not tune specific are they? In other words, if I set custom options for a Level 1 tune, then later change to Level 3 and "Load Previous Settings", I get the options I set for Level 1 back again, don't I?
(I'm glad you live as far away as you do - I might be afraid you'd come beat me up over my failure to understand this "feature" if you were closer). :o
