Old Thu, April 7th, 2011, 07:37 AM
dixiefishing dixiefishing is offline
dixiefishing is on a distinguished road
OK thank you - I will do it tonight. I picked the truck up last night - and sure enough on level 2 it started the codes. I set it back to stock and the truck ran great and has been running great. But now the edge reads a dtc on stock setting - P1000 OBD readiness test not complete. It will clear out - but will come right back. I took the edge in to use my Fusion software to try to upgrade it - which it did upgrade and re calibrate. Took it back out and installed it at stock setting and still the P1000 code. I have not reset it back to level 2 - so I am really thinking it has to do with the edge itself. I will set it to 1 tonight after work and see what happens.
