Old Thu, February 26th, 2009, 08:34 PM
drug delivery drug delivery is offline
drug delivery is on a distinguished road
Wait, stop! We may be saying the same thing under different assumptions. I enter Custom Options and "Load Previous Settings" as my first option. Now I make a few changes, and select "Done" to start the programming. Doesn't this create a new "Previous Settings" file that is the sum of both the previous options and new ones I've entered? So, couldn't this be thought of as cumulative?
Boy, I am confused. For example. If someone changes their timing +1, then at a later time changes the timing again by +2, then the net effect is +3. However, if before making the second change they had loaded previous settings, then the second change of +2 is a net of +2. Under this scenario it's only cumulative based upon what was done post "previous settings".
But, if you chose a tune, then open the Custom Options menu and select "Done" as your first action - I believe you are saying this will effectively "wipe out" all previous custom settings you may have had (and additionally may load bogus values for GR and TS).
Are you saying when you simply select "Done" that the original tune loads? I thought that the custom changes would basically wipe out the original tune and you are left with what changes you've made, cumulative or not.
AND, I want to verify one more thing. Custom options are not tune specific are they? In other words, if I set custom options for a Level 1 tune, then later change to Level 3 and "Load Previous Settings", I get the options I set for Level 1 back again, don't I?
I too would like an answer to this.
