Old Sun, April 17th, 2011, 12:48 PM
RacinJasonWV RacinJasonWV is offline
RacinJasonWV is on a distinguished road
OK I have one more issue with the Insight. I tested it with a pressure pump last night on the map sensor. The gauge will only show 22psi max, after that it goes to 0 and the truck has to be keyed off before it will reset. So if you are going to use a wastegate controller like I am planning, you are going to need another gauge. Other than that it is great.
01 F250 Auto, CSD T4, 363/68/0.91, AIS, 4" Magnaflow exhaust, Insight CTS, Hydra w/ PHP tunes
65 Falcon 289cid Dragcar
