Old Sun, April 17th, 2011, 06:36 PM
You MAY need to login to their Flashchat system and make sure Bill or Cody knows about this. Since I haven't seen any response from them in this thread, I doubt they are aware of your needs.
But, since you've downloaded Pegasus, start it up and plug your Gryphon into the PC. (Make sure you returned your truck to stock before removing the Gryphon.)
Then, when Pegasus shows that your Gryphon is connected, click on [Updates]->[Custom File Download]. If your custom files are still on the server, they will be found and you can go ahead and install them. This is worth a try and won't hurt anything if they're not there.
