Old Tue, April 26th, 2011, 10:17 PM
BigSur BigSur is offline
Scientist
Good info, thanks Jack. The Gross Axle Weight Rating on each of the 2 axles is 3500lbs. The dealer IS supplying a distribution hitch with the purchase, so I'm good there. Dry weight is "around" 4800 lbs....the GVWR is 7500. I really would be surprised I go much further than 5500 lbs.....we really don't carry all that much and I will likely always travel with empty water tanks. In any event, I do like your advice to have it weighed. I just need to figure out where the best place to do it is.....do most standard inspection stations have them? Also...off the cuff, do you know what the front/rear axle ratings are for an F150? Something tells me you know this by heart, but no biggie....I can easily pull my manual or find it online. Thanks again.
