Thread: need help
Old Wed, April 27th, 2011, 08:24 AM
Are you sure you're not looking at this from an accelerator pedal feel standpoint? Most other tuning companies make the accelerator pedal feel like an on/off switch and command full fuel by about 1/2 "throttle". Besides, BullyDog has fairly aggressive "timing" on their tuning and yes, it does give the truck a more sprightly feel.
You really need to do some diagnostics on your truck, Bill. It shouldn't run like a complete turd as there are a lot of the same 99.5-01 manual trucks running around with the exact same tuning you have (OneMeanStroker from this thread for instance).
As for Shawn, I'm beginning to wonder if Brian's truck has stage 2 injectors or not...if it runs fine with canned programming from Superchips, he does not have single shots nor larger nozzles.
