Old Mon, May 2nd, 2011, 06:25 PM
Originally Posted by Medic150 View Post
Ive read the instructions several times and installed my gryphon today. I installed the tranny tune just to get used to the way everything works. I can immediatly feel the difference. It feels much more responsive. I only went around the block to make sure all was ok.
In the instructions, I did not find a section that shows how to return the truck to stock.. what is the proper procedure to do this ??
Thanks guys !! This forum has been really imformative. Even to my dumb newbie questions
When you access the power programming menu again, you'll find there is now a "Return to Stock" selection. (It may have a slightly different name.) Just select it and it will return the PCM to stock. And by the way, to answer a question that's often asked, this is the ONLY way the PCM is returned to stock. Disconnecting the battery or the programmer does not "lose the tune".
