Old Mon, May 2nd, 2011, 09:01 PM
Originally Posted by Medic150 View Post
I just went out for a test drive. I set ttruck on the tranny tune and tried a 0-60 run to see how it works.
During regular driving. The truck feels really solid and feels torquy.
But while doing the 0-60. I stepped on it hard and it started to like surge looking for a gear then it finally shifted into gear pretty hard. I pulled in to the gas station for some gas and I noticed the unit stayed on when I shut the truck off.
And my unit is stuck on the 0-60 finished test screen. I shut the truck down but the unit stays on.
When the Gryphon screen stays lit after shutdown, it's generally a sign of a failing battery. Please disconnect your Gryphon from the OBDII port (the lit screen will rapidly deplete a weak battery) and have your battery load tested.
When you reconnect, make sure the ignition is ON, before you plug the Gryphon in so that it can boot properly.
