Old Fri, May 6th, 2011, 08:57 AM
wood4heat, what is your PCM code? Longshot270 had some really great information there, but as far as the 4R100 is concerned it is a little off....
Under normal acceleration, the TCC is commanded to apply in 3rd gear at some point (Depending on PCM code, which is why I asked for it).
If you can truly FEEL the 1-2 and 2-3 upshifts under normal acceleration, it's likely you have something done to the transmission. Typically, with stock programming and a stock transmission, the 1-2 and 2-3 upshifts SLIDE into gear and you really don't notice much of an RPM change.
