Old Fri, May 6th, 2011, 05:53 PM
Originally Posted by str088 View Post
Another question, just how sensitive is the error sensor for the programmer?
I'm guessing it's more sensitive than the trucks stock ecm, but just how good
is it? Thanks in advance.
No, it tells you what error codes the PCM is reporting. The Gryphon is not "polling" the sensors at all, the PCM does that. "Sensitivity" is not an issue in the Gryphon.
