Thread: need help
Old Sat, May 7th, 2011, 04:09 PM
bill1980 bill1980 is offline
bill1980 is on a distinguished road
in stock at idle.
injector control pressure. 548-560psi
manifold pressure 13.02psi 26.5 inhg
waste gate duty cycle 18%
stock under load/ heavy acceleration
injector control pressure 2400-2600psi peak was 2743.11
manifold absolute pressure 22psi 45inhg
fuel pulse width 2.4 msec
wastegate duty cycle 98.8%
no codes before or after stock test
chip on 100hrs load/ heavy acceleration
injector control pressure 2350-2550psi peaked was 2611.24
manifold absolute pressure 29.35psi 49.2inhg
fuel pulse width 2.2msec
wastegate duty cycle 94.3%
when on the 100hrs setting these codes came up while testing.
p1249 p0603 p0340 p1211 p1249 p0603a
the computer i borrowed was a genisis updated with 4.0 obdII. it wouldnt read oil pressure.
not sure if this helps or not. if you need more info let me know i have the computer till tuesday.
