Thread: need help
Old Sat, May 7th, 2011, 05:26 PM
Originally Posted by bill1980 View Post
in stock at idle.
injector control pressure. 548-560psi
manifold pressure 13.02psi 26.5 inhg
waste gate duty cycle 18%
stock under load/ heavy acceleration
injector control pressure 2400-2600psi peak was 2743.11
manifold absolute pressure 22psi 45inhg
fuel pulse width 2.4 msec
wastegate duty cycle 98.8%
no codes before or after stock test
Looks good to me there.
chip on 100hrs load/ heavy acceleration
injector control pressure 2350-2550psi peaked was 2611.24
manifold absolute pressure 29.35psi 49.2inhg
fuel pulse width 2.2msec
wastegate duty cycle 94.3%
when on the 100hrs setting these codes came up while testing.
p1249 p0603 p0340 p1211 p1249 p0603a
the computer i borrowed was a genisis updated with 4.0 obdII. it wouldnt read oil pressure.
not sure if this helps or not. if you need more info let me know i have the computer till tuesday.
See bold/underlined above. The P1211 is normal for a chipped truck and a stock HPO system.
There is one more thing I'd like for you to look at for me. When the injection pressure (ICP) is around 2300 PSI under load, what is the injection pressure regulator (IPR) doing? That value will be in "%" and expressed as duty cycle. If you can (SAFELY!!!), run the truck from 45-80 MPH in 6th gear WOT. Watch the ICP and IPR as well as the pulse width value at that time. Thanks!
