Old Wed, May 11th, 2011, 11:46 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
That guy...
ToMang07 is on a distinguished road
Originally Posted by 907DAVE View Post
One thing I do with mine is to remove the box and use that small grounding tab (on the lower 7MM bolt) to keep the PCM up against the firewall. This also acts as a case ground for the PCM.......whether its necessary or not - I could not tell you.
I fashoned a little "Z" shaped brackt... attached a rubber runner on the PCM mount and a rubber "arm" on the bracket....and used the lower screw on the stock mounting bracket as well. I think I will go get a pic... could come in useful!...
02 F-350 Super Duty SCSB 4x4 SRW 7.3L TD, DIY-I, PHP-6 Phoenix, 4" Turbo-Back 409 MBRP, Glowshift 3 in 1, Fisher 8' MM2
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
