Old Thu, May 12th, 2011, 09:11 AM
Originally Posted by 907DAVE View Post
One thing I do with mine is to remove the box and use that small grounding tab (on the lower 7MM bolt) to keep the PCM up against the firewall. This also acts as a case ground for the PCM.......whether its necessary or not - I could not tell you.
You go a lot further than I do.
The 2000 PCM is flopping around; only being held in place by the wiring harness. The PCM in the 1995 is resting between the underhood fuse box and brake master cylinder.
