Old Mon, March 2nd, 2009, 11:15 AM
Originally Posted by orygunf150 View Post
Well I was hoping to hear from Bill on this one (I'm sure he is pretty busy) but there is a definate reduction in power. I monitored comm gear while taking off in 2nd gear, after a few seconds shifted to 3rd and it took off like a different truck. Didnt shift to 1st, nor did the tc ever lock. I wonder if it does it in 4WD?
For some reason, I've noticed that the truck will go into a reduced power mode in Manual 2nd Gear. I'm not sure what the purpose of this is other than to prevent burning up the clutches in the transmission by trying to start from a dead stop in 2nd gear. I've never really been concerned about it since this is not a normal driving situation for most folks.
By the way, you can manually recreate the symptoms. Put the truck in 2nd and take off from a stop. At about 30 MPH, matt the gas pedal and after a second or two shift from 2nd to Drive. You'll instantly feel a change in power output. Make sure you're not downshifting when you switch to Drive or it makes the whole test pointless.
