Old Sun, May 15th, 2011, 07:55 PM
wood4heat's Avatar
wood4heat wood4heat is offline
wood4heat is on a distinguished road
wood4heat, what is your PCM code? Longshot270 had some really great information there, but as far as the 4R100 is concerned it is a little off....
Under normal acceleration, the TCC is commanded to apply in 3rd gear at some point (Depending on PCM code, which is why I asked for it).
Just took a look, my code is VDH5. Does that tell you anything?
I would also still like to know if the 3-4 shift can be cleaned up without changing the 1-2 and 2-3 shifts.
Would it be best just to call in before filling out the order form?
