Old Fri, May 27th, 2011, 10:01 AM
A "touchy" pedal is just the way the PCM has been reprogrammed to respond to pedal movement, since everything is electronic. It can be programmed to have a different "feel" if your friend finds it objectionable. Much of this is due to the way Bill perceived your friend's tuning goals were.
It is neat being able to adjust the accelerator pedal feel electronically. It sure beats toying with different pedal linkage geometry and throttle shaft eccentric shapes......
Nothing beats a mechanical linkage or cable for tactility, but if adjustments need to be made, it's not impossible to make the pedal as dead as you can tolerate or touchy as you can control.
