Old Sat, June 25th, 2011, 08:56 PM
KIRT KIRT is offline
KIRT is on a distinguished road
No Kirt -
You make sure the Gryphon is using the actual Gear Ratio (GR) that is INSTALLED in your truck.
I'm not sure what "reference" you are talking about though. It COULD be that installing larger tires reduces the "effective Gear Ratio" on your truck, which it does. Or, that to regain the "stock GR feel, power, etc." after installing larger tires you would have to install higher gears, which is also true.
Thanks Jack....I do think it is talking about changing the actual gears....like I said it was kinda vague
2007 F150 XLT 5.4L: 3" SISO MAG: VOLANT CAI: GRYPHON TUNER
