Old Fri, July 22nd, 2011, 07:20 PM
cj45lc cj45lc is offline
Originally Posted by txjeep View Post
Okay, thanks again. I figured out the wiring and what to do now, so I am going to remove it.
I assume the Banks chip comes out in the reverse order that the PHP chip goes in?
Did you get the trans wires straightened out?
Yep the chips should just un-plug & plug-in from the PCM, they say to make sure the key is NOT in the ignition when you do it but I always un-hook the batt cables when I fool with the chip
