Old Tue, July 26th, 2011, 01:41 PM
God & Guns
The way I did it, is if my transmission is searching gears a lot (in and out of OD) I'll just turn the OD off.The transmission knows when to give you more "umph" if you are needing it, so if its not changing in and out you are good with leaving OD on IMO.
