Thread: Over boost
Old Tue, August 2nd, 2011, 09:26 AM
The 95-97 trucks aren't as accomodating for tuning changes that allow you to "ignore" boost. Your definition (as well as ours since they're the same) doesn't have any MAP sensor parameters.
If you want to try to run your boost higher than that ( ) you will need a regulator put in the MAP sensor hose.
