Old Wed, August 3rd, 2011, 02:59 PM
I may be misunderstanding you, but the truck WILL be in 4wd (and all tires transmitting power to the asphalt) regardless of what you do with the transfer case switch after a 4wd launch.
The rear tires will never push the fronts down the track as the truck will continue to stay in 4wd until you lift at the traps.
